Best Options for shipping/delivering a motor to HKE in Houston?
Old 01-08-2009, 11:32 PM
WizeAss's Avatar
Default Best Options for shipping/delivering a motor to HKE in Houston?
I believe the shop should be close to having my motor out.... what do yall suggest? What is the least expensive option? I am sure I can pay Erik to ship it back or find a way to pick it up?
Old 01-08-2009, 11:48 PM
Ls1ChevyII1963's Avatar
Where are you located?
Old 01-09-2009, 04:40 AM
streetassasin's Avatar
gas is cheap, borrow a truck
Old 01-09-2009, 06:58 AM
Black2001z06's Avatar
What happened?
About $200-$300 each way...
www.freightquote.com
Old 01-09-2009, 07:36 AM
Greed4Speed's Avatar
Did you break it again or just tinkering some more?
Old 01-10-2009, 09:23 AM
aggiez28's Avatar
look up globaltranz. they have shipped a few engines for me and they allways got me the best rate
Old 01-10-2009, 10:59 AM
daniel6718's Avatar
wtf happened to your motor?
Old 01-10-2009, 12:42 PM
WizeAss's Avatar
didnt really break....
Basically the same issue. Still not fixed.
Driving me completely insane and sucks ***.
The car cuts off at 5200-5300rpm every pull and on the street. It looses signal/timing for some reason and then all the unburnt fuel explodes in the exhaust and at the wrong time. Completely violent in my opinion.
RPM has replaced all the crank wiring, crank trigger, cam, and everything else. Only thing it can be is the reluctor wheel or crank back and forth in the motor. It ran fine for a long while and now this happened.
Sucks but it is what it is.
Old 01-10-2009, 12:52 PM
Hate to hear that man. You've been through the ringer with your build.
Old 01-10-2009, 12:57 PM
No he hasn't...
Old 01-10-2009, 01:01 PM
WizeAss's Avatar
Originally Posted by Black2001z06
No he hasn't...
x2...... you have gone thru the ringer.... I have been thru just a wash or two.
Justin's pain was greater than mine... If this doesnt fix the car I swear I will spend 2009 parting it out and work on getting a C6ZO6!
Old 01-10-2009, 01:03 PM
If thats the build from the other "engine builder" in Houston I've heard about that. That is far beyond ringer there. You should have gotten some KY with the engine. I had a bad enough experience with my junk and probably wouldn't have handled your probs as well.
Old 01-10-2009, 01:18 PM
They are making it right.
I just tried handling it sanely and as professional as possible.
Old 01-10-2009, 03:50 PM
Thats good to hear. Hope it all works out in the end for you.
Old 01-10-2009, 04:06 PM
Texfinn's Avatar
If you are not in a big hurry, I'm going to Houston with my truck in the next week or two. As long as I don't need to wrestle with that engine of yours too much in either end, I can probably fit another motor in there.
Doesn't cost you much.
Old 01-10-2009, 10:07 PM
WizeAss's Avatar
might be a good deal!! for both of us!
Quick Reply: Best Options for shipping/delivering a motor to HKE in Houston?
