85 MM LS2 or larger MAF?
Old 01-09-2009, 07:58 AM
SuprJames's Avatar
Default 85 MM LS2 or larger MAF?
Hey all. I have a '72 Vette project that that has a LS1 with LS6 heads, Lingenfelter GT2-3 cam, and a C5 Maggie supercharger. I put a LS2 snout and a 90mm manual UMI throttlebody on the maggie, and was wondering if I should go to a larger MAF.
I have the 85MM LS2 MAF, but was wondering if I should bump it up to a larger one like the Lingenfelter 100MM unit. Will 5mm make much of a difference?
Some pics and vid...the intake is temporary until I find out what I can do to clear the hood:
http://www.youtube.com/watch?v=sYWlxzv7_9s
Old 01-09-2009, 12:43 PM
NastyC6's Avatar
90mm is the way the go for the budget price. 100mm will cost you some $$, but either will help with what you've got going on.
Old 01-09-2009, 12:48 PM
Moderator
JayplaySS's Avatar
Twin Screws and Roots are very inlet restriction sensitive (around 17-20lbs) so I would go ahead and grab the larger MAF. Either way, its only going to help.
Old 01-10-2009, 03:19 AM
LilJayV10's Avatar
Very sweet car. I love the side pipes.
Keep us updated.
Leave the intake the way it is. You don'ts need no stinkin hood!
And put some shoes on.
Seriously though, love the car. Did you do the whole thing yourself?
Old 01-10-2009, 08:33 PM
SuprJames's Avatar
Keep us updated.
I did everything except modify the sidepipes and most of the bodywork and paint was done by a friend. My dad is a hot rodder from the 60's, and it was fun tearing into that LS1 with him. He's since purchased a 6.0L for his '37 Chevy coupe
Car should be painted next month....black, and not matte though it is very tempting.
So 90mm or larger would be a wise investment? Best brand?
Old 01-10-2009, 09:52 PM
qqwqeqwrqwqtq's Avatar
I would just ditch the maf alltogether and run it speed density.
Old 01-10-2009, 11:59 PM
Frost's Avatar
Absolutely!
Old 01-11-2009, 02:12 PM
Gingervitis Addict
slow67's Avatar
Originally Posted by intmd8
i would just ditch the maf alltogether and run it speed density.
..x3!
Old 01-11-2009, 07:01 PM
Z06PSI's Avatar
x4!!!
Old 01-13-2009, 06:05 AM
SuprJames's Avatar
I've thought about that option too, but I've heard it's not really necessary with the Maggie and that for street driven cars MAF is more flexible. Other then looks of the intake what would be the other advantages?
Old 01-13-2009, 08:45 AM
NightMoves's Avatar
Why? I'm on SD now but only because of clearance issues. What are the Pros & Cons? I believe both Ford & GM have in the past gone from MAF to SD then back to MAF, why?
Old 01-13-2009, 11:24 AM
Mr.Big's Avatar
use the Haltech 103.5mm maf with the GM LS3/7 card style maf insert, this is not just for flow, but for superior tuning. With these new maf's S.D. is no longer the way to go imho... I've spent tons of time since '05 working on FI tuning through different MAF's on my setup, my setup carburetes flawlessly...
Old 01-13-2009, 01:07 PM
Frost's Avatar
It doesn't matter, the 512g/sec airflow value in the PCM is fixed, the MAF isn't the limit, the hardware is. I tested several card MAFs quite extensively, they are in the same boat for FI as any other MAF on a GENIII PCM.
Old 01-13-2009, 07:51 PM
SuprJames's Avatar
Wow, I'm researching this and my head is spinning right now. I'm guessing that this is what I'm looking for?
http://www.halltechsystems.com/product_p/h103.htm
OK, so I know the car has to be tuned for that, but will the LS1 computer work with the LS7 card style MAF or do I need a LS3 computer or a patch?
What exactly is the g/sec stand for as I keep seeing it reference in MAF threads, but no explanation as to what it is. So you think speed density is the way to go?
Old 04-29-2009, 06:10 PM
The Fugitive's Avatar
same question here, I was just told by a tuner I would be a lot happier with a 100mm MAF than going with a SD tune. Is the difference in drivability or is it just better for boost for seeing more pressure in the manifold?
Old 04-29-2009, 06:12 PM
and what are the pro's and con's of both?
Old 04-30-2009, 12:47 AM
Frost's Avatar
There are work arounds (IFR/MAF/VE scaling) to run a MAF past traditional limit (lie to the PCM about real airflow) but SD IS snappier than running a MAF on GenIIIs. This is part of the draw of the S/C is the instant hit, and SD works well with that. SD drives very well also.
Old 04-30-2009, 02:38 AM
is there a problem with going 3 bar right from the start even working with low boost? Or is it progressive and I have to work my way up to a 3 bar?
Old 04-30-2009, 10:24 PM
99Ls1fever's Avatar
Sorry to ask but what is SD? I searched for this topic " 100mm MAF sensors" cause at the track I am running forced induction with spray and my tuner said to look into a lingenfelter 100mm maf because my stock one isnt keeping up with my car. I was just checking to see what is the best route and what SD Means? thanks
Old 11-07-2009, 11:14 PM
a lil help with these remaining questions
Quick Reply: 85 MM LS2 or larger MAF?
