Oil Pressure Question
Old 01-09-2009, 05:54 PM
70Formula's Avatar
Default Oil Pressure Question
I have a 2000 WS6 Formula with less than 30K miles. Just recently the oil pressure has gone up and at idle is about 50 psi, 60 while I am driving, and probably 75 psi if I get on it. I also have a 99 30th with 46K miles and the oil pressure is about 40 psi while at idle and never goes above 60 psi even when I am driving it hard. Is this a normal range for the Formula because I am worried that maybe something clogged the oil pump and I don't want to damage the engine. Both engines make some clicking sounds when they first start but once the oil warms up it goes away. Any insight would be appreciated. Thanks guys.
Old 01-09-2009, 08:23 PM
jomomma's Avatar
id say your looking alright.the clicking noise is the lifters pumping up with oil.
Old 01-09-2009, 09:28 PM
IWGF's Avatar
Oil pressure looks decent to me mang.
Old 01-09-2009, 11:55 PM
01ssreda4's Avatar
^^^yeah sounds like good pressure to me too.
Old 01-10-2009, 12:39 AM
bluehawk2's Avatar
sound like good pressure to me, but it does make you wonder a little..........like maybe there is a oil passage stopped up making a restriction...................but, if that was happening the engine would make some odd noises
really don't think you got anything to worry about that is a normal opperating range u just have good pressure
Old 01-11-2009, 04:14 PM
70Formula's Avatar
Thanks for the advice guys. I checked it today and after it had warmed up I put it in neutral and it was 60 psi at idle and by 3500 RPM it was at 75 - 80 psi. That still seem okay because that is more than the 10 psi per 1000 RPM and it has me a little worried. Thanks for the help.
Old 01-11-2009, 05:01 PM
hawk18's Avatar
Default pressure
did you do any thing like just change the oil.
Old 01-11-2009, 07:49 PM
bluehawk2's Avatar
What kinda oil you run
Old 01-11-2009, 10:13 PM
70Formula's Avatar
I just changed the oil 2 days ago, it is Mobil 1 Synthetic 5W30
Old 01-12-2009, 08:14 AM
bluehawk2's Avatar
Another factor is the weather is colder so your oil temp is prolly going to be cooler.
I wouldn't worry about
