Finally Ordering Parts
Well guys here is the list of parts I'm ordering for my car. What do you think:
Already bought:
- stock LS6 243's (Should I get them ported?)
Ordering Soon:
- Torquer v3
- PRC Springs Kit
- TSP hardened push rods 7.40"
- TSP ported LS6 oil pump
- Basic Heads & Cam gasket/bolt kit (Cometic head gasket 0.040")
- LS7 Lifters
- LS2 timing chain
Am I missing anything?
Does everything seem compatible?
Thanks
Matt
Already bought:
Ordering Soon:
- Torquer v3
- PRC Springs Kit
- LS7 Lifters
- LS2 timing chain
Thanks
Matt
Also, I'm 90% sure the ls6 heads have center bolt valve covers, and your 98' has parameter ones. so... you're going to need new-style valve covers, you should double check that to make sure. Yes, get your heads ported.
LS1Tech Premium Sponsor
There's some inexpensive HP to be had from getting those LS6 heads ported! Give us a call. We can set you up with CNC porting and valve job starting at about $650.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
