My Truck Manifold Build
Old 01-09-2009, 11:42 PM
blazin's Avatar
Default My Truck Manifold Build
I am just starting my truck manifold build
Here is a pic of the old lt1 setup
Here is the same car with the ls1 swapped.
The Run Down
Flipped truck manifolds
Lucas 42lb injectors
MP T70 .96ar
Ebay 38 MM Wastegate 6 PSI Spring
Ebay RFL BOV
Ebay Intercooler
224/224 112LSA
9" with 4.11s
T56
Im not looking for everyones opinions on the ebay parts. Im just showing my build.
Here are some pics from tonight,
I got the injectors swapped,new tune loaded,ac,alt removed. Manifolds mounted. PS lines re routed out of the way.
I ran into a problem on the passenger side tonight. The rear stud was hitting the k member so I torched that out and now that the manny is mounted the stud is so close to the frame rail there is no way to get a nut on it. Tomarrow I will remove the studs and try some bolts or allen headed bolts. Open to suggestions.
Old 01-10-2009, 03:10 AM
LilJayV10's Avatar
Looks good. Did you move the top radiator hose? It looks like it might get cooked in the first pick.
Also, are the 4.11 gears to deep for a turbo car? I am just asking. Don't take it as a flame.
Old 01-10-2009, 03:23 AM
simple's Avatar
you could remove the one stud and put a bolt thru it so the nut is on top.
another possible option is you could cut off the flange and rotate. mount the manifold back on with out the flange, hold the flange up to the manifold and mark its place when it clears everything, then weld it back on.
i'm not sure how that will work out on cast iron tho. (maybe a shop or or veteran welder could do it)
curious what manifolds you used on the old LT1 setup?
Old 01-10-2009, 03:40 PM
frcefed98's Avatar
Pull all studs replace with SS cap screws and SS washers. The stock studs are prone to rusting
Old 01-10-2009, 07:53 PM
98turbls1's Avatar
You can say that again.. It took me and my nephew with craftsman professional vise grips turning at the same time to get mine out.. They are a bit stubborn. BTW I'm having the same problem with that same location. It looks like a bolt is going to have a tough time too.. Does any have any suggestions?
Old 01-11-2009, 09:13 PM
frcefed98's Avatar
Shoulda bought a 10 dollar stud puller from pepnapaautocheckers to pull the studs...much easier that way and with a can of PB blaster.
yeah tubular K member and you won't have any issues. Plenty of people have used the stock K member, but had to notch it...how much I don't know as I've had the BMR K member on the car since my procharger days. It can be done tho.
J
Old 01-11-2009, 11:03 PM
blazin's Avatar
Originally Posted by mightyquickz28
M6, 4.10 gears in a hybrid Ford 8.8/GM 10 bolt differential, Nitto DR and 3,650 lb daily driver. It is a ton of fun and drives like a stocker off boost but is absolutely wicked once it gets into boost. The 4.10's get me off the line quickly and once you plant the gas pedal it just slaughters the cars and sport bikes I've raced. I got another sportbike (not sure but it looked like a 7xx cc) today. The car doesn't creep past the bike, it walks briskly past him in third. I had to let off at the top of third because the rear of the car was starting to slip sideways. I feathered it a little, got straight and then finished the execution. I like 4.10's
After reading this and having the 4.11s already in the rear I figured I would try them.
Old 01-15-2009, 09:55 PM
blazin's Avatar
Flanges are holding me up.
Old 01-15-2009, 10:04 PM
dman's Avatar
cut them off and weld v-bands on.
Old 01-17-2009, 12:22 PM
blazin's Avatar
I have them on order just going on 15 days of waiting. I think I would rather have v bands but these might show up in the next few days lol.
Old 01-20-2009, 08:37 PM
blazin's Avatar
Where can I get stainless studs at? Still waiting on flanges.
Old 01-20-2009, 10:28 PM
frcefed98's Avatar
Believe it or not, Home Depot has em.
They are in the fastener section in the big bolt chests...the ones with the slide out drawers.
They get a bit spendy, but are worth it.
J
Old 01-22-2009, 10:15 PM
blazin's Avatar
Hotside is pretty much done. Have to put 02 bungs in and misc little crap like the gate and ect. Here are crappy cell phone pics.
Old 01-23-2009, 01:35 PM
98turbls1's Avatar
Nice man.. Still cracking at mine but am wondering if I should put it off for a bit so that I can order the new Camaro.
Old 01-25-2009, 01:46 AM
blazin's Avatar
Here is a update. All the piping for the hot side is complete. I got most of the cold side put togther tonight. Things left to do
Install Pillar
Tap Pan
Run Gauges
Alt Relo
Finish Cold side.
Old 01-25-2009, 05:27 AM
LilJayV10's Avatar
This is a little off topic but what is the big metal thing inline with the top radiator hoses?
Is that so just a regular hose isn't above the turbo or something else.
Old 01-25-2009, 09:33 AM
Silver_TransAm's Avatar
Thats the power steering cooler.
Old 01-29-2009, 10:34 PM
blazin's Avatar
Here is a update with some more shitty camera phone pics. Its all done but cant start it because im waiting on a damn drain line and flange.
Drain and flange will be here 2-2
Old 01-29-2009, 10:45 PM
stagemonster's Avatar
+1 on that
Old 02-01-2009, 03:32 PM
blazin's Avatar
Here are some better pics. The car is 99.8% complete. Waiting on the drain flange and line to get here then it will be 100%. Should be able to test drive it tuesday night!
Ground Clearance is awesome
Quick Reply: My Truck Manifold Build
