EVAP system
Old 01-10-2009, 07:18 PM
Big Bird WS6's Avatar
Default EVAP system
what is the delete process to turn this off?
thanks
Old 01-11-2009, 05:54 AM
How do I change this text
Wilde Racing's Avatar
What tuning software are you/your tuner using?
Old 01-11-2009, 03:26 PM
efi live
Old 01-11-2009, 03:27 PM
and what do i do with the system. just put a breather on the tank? or a line off the tank?
Old 01-11-2009, 05:47 PM
nemss1's Avatar
yup breather
Old 01-12-2009, 01:43 PM
bump for tune answer
Old 01-14-2009, 10:40 AM
bump bump. please
Old 01-16-2009, 03:20 PM
anyone, please , thanks
Old 01-16-2009, 03:32 PM
2xLS1's Avatar
I've never seen anything in any vehicle calibrations that controls the operation of the Evap system. AFAIK, all you can do is remove the parts from it and set the Evap DTC codes to no error reported. Just go through the DTC list and find everything that has Evap in the description.
Old 01-17-2009, 10:58 AM
pdsq98gt's Avatar
Why are you deleting it? Not like it's going to purge under WOT anyway.
Old 01-20-2009, 10:28 AM
^ ^ clean look.
and two ^ ^ . is that it. just delete the codes?
Old 01-23-2009, 12:51 AM
kelp's Avatar
Unplug the purge valve. It won't screw your AFR at those "inoppertune times"
