Widest Welds in front?
I currently run 15x8 rear and 15x3.5 Pro Stars on my car. I'm tired of swapping between those and my C6s, so I sold the C6s with ideas of running my Welds only on the street. The problem is, braking and handling are terrible with the skinnies.
What would be the widest I could run in front, stock calipers not ground down, with 5/8 spacers that are used anyways for the skinnies. 15x6?
Thanks.
Thanks.
I coulda sworn I'd seen wider, again maybe 15x6, with some weird offset on stock brakes.
I had these shouldered lugs and swapping the wheels as much as I do, but may go back to 18s/19s for the street.
Thanks.
Thanks.
I'd suggest considering picking up a set of 17's again. Anything else in 15's large or small will be terrible in comparison. This is due to the large sidewall which you're left with.
