does anyone make tubular front bumper supports?
Old 01-11-2009, 10:44 AM
azzsmasher69's Avatar
Default does anyone make tubular front bumper supports?
looking to remove my bumper support but dont want the front to sag.
Old 01-11-2009, 10:45 AM
94 camaro btw
Old 01-11-2009, 02:50 PM
robsquikz28's Avatar
how would the front end sag when removing the bumper support it will look the same after removal but i would recommed to never let some1 sit on the front bumper....if you want just remove the clamshell but leave the brace or like i have done before for peeps just cut several chunks out of the brace and leave the middle part of the brace alone so it still does something rather than nothing as a crash support
Old 01-11-2009, 04:32 PM
flyinZ's Avatar
Burkhart Chassis(sponsor, I think) made up a few...I THINK they started to mass-produce them to sell..You'll have to ask them.
Old 01-11-2009, 04:55 PM
joelster's Avatar
Yes it will sag a bit with nothing under there. It will flatten a bit at high speeds too. Burkhart makes one, but it's only for a Firebird or a Trans/Am. I'm not sure how much modification would be required to make it fit the f-bod front end.
Here it is:
Yes they are a sponsor, here is their link:
http://www.burkhartchassis.com/
Old 01-11-2009, 05:02 PM
AChotrod's Avatar
Damn I think you just gave me a reason to take out my bumper supports!
Old 01-11-2009, 05:45 PM
flyinZ's Avatar
I dont know if they ever made up a set for a camaro, or not. Have to ask..If not, now would be a good time to make a set.
Old 01-11-2009, 06:02 PM
The Batman's Avatar
the bumper would probably look like **** after a year of sagging without the foam supporting it. fck that. seen 3rd gens do it b4.
Old 01-11-2009, 06:06 PM
RamAir95TA's Avatar
With a welder and some steel stock it wouldn't be difficult to make your own.
Old 01-11-2009, 07:46 PM
F3RR3T's Avatar
Few layers of 1.75 oz fiberglass on the backside of the bumper would solve that
Old 01-11-2009, 08:43 PM
GIZMO's Avatar
You could always make a new bumper from aluminum and attach the stock foam to it.
Old 01-11-2009, 09:46 PM
8 Second 6 Speed Director
taner's Avatar
Location: windsor, ont. canada - Home of the fastest LT1 6spd.
my car is living proof it WON'T sag.
Old 02-11-2009, 12:42 PM
Hot Copper Z's Avatar
Here's one that me and my buddies made for my car. We made some extras to sell and we have sold two already.
It weighs around 9lbs and is made out of chrome moly. Here is the link.https://ls1tech.com/forums/drag-raci...r-support.html
Old 02-11-2009, 01:04 PM
SprayedLT1's Avatar
How much?
Old 02-11-2009, 01:07 PM
$250.00 shipped and they are powder coated in black.
Old 02-11-2009, 03:52 PM
blackz6sp's Avatar
Now whats the weight difference between factory bumper and support and your tubular peice?
Old 02-11-2009, 04:06 PM
The factory support weighs around 29lbs and the piece we made is 9lbs about a 3rd the weight,a whole lot lighter,stronger and made of chrome moly.
Old 02-11-2009, 05:35 PM
flyinZ's Avatar
looks like a stout piece. I wonder if that is as strong or stronger than the factory piece, if you were in a fender bender? (low mph of course) Just a thought..
Old 02-11-2009, 06:22 PM
James Montigny's Avatar
I used three small strips of aluminum between the airdam and where the bumper cover snaps in.
Nose looks just fine. I just don't see any reason for a full tubular streel/CM frame under there.
At the very most, an aluminum hoop with an angled support under it.
Having said that, I've seen vids of card with no support whatsoever that do sag under acceleration.
Old 02-11-2009, 07:01 PM
Black94Z28's Avatar
you have any pics of your setup james?
Quick Reply: does anyone make tubular front bumper supports?
