396 fuel system
Old 01-11-2009, 10:51 PM
screming_z28_95's Avatar
Default 396 fuel system
would a stock fuel system work for a 396 if i through some bigger injecters on or will i need a new pump etc..
Old 01-11-2009, 11:01 PM
sweet-94z28's Avatar
you will wanna get a walbro 255 fuel pump because I don't think stock will keep up, but I guess it could depend on the cam size.
Old 01-12-2009, 09:44 AM
ss.slp.ls1's Avatar
+2 on the walbro 255 for peace of mind. I think it is capable of supporting like 700hp.
Old 01-12-2009, 10:45 AM
Stroked96Bowtie's Avatar
You can hurt alot of things running it lean...the trap door method of replacing the fuel pump isnt too complicated and worth the peace of mind. Just did one yesterday actually
Outside of that, all the stock lines, etc will be fine.
Old 01-12-2009, 03:46 PM
96capricemgr's Avatar
Depends on the 396, you could conceivably put one together that would be fine on the stock fuel system. The fact all you mentioned was displacement raises a flag to me and makes me wonder if you draw a direct connection between size and power???
Displacement is not really even a consideration in fuel system selection, airflow is, and displacement does not dictate airflow.
If the engine works well you will need a Racetronix kit with Walbro pump and wiring upgrade and new injectors, the lines and regulator are just fine.
Old 01-12-2009, 04:52 PM
ss.slp.ls1's Avatar
True, but most people who build a 396 aren't exactly going for a mild build.
Old 01-12-2009, 05:00 PM
fuel's Avatar
buy a race tronix with the wiring kit its worth it
Old 01-12-2009, 05:08 PM
Thing is most people who think displacement is the critical factor don't endup building anything particularly powerful either. They fixate on displacement and neglect the truely important pieces and endup with a big expensive mediocre performer.
Old 01-12-2009, 05:13 PM
ss.slp.ls1's Avatar
Also true in some cases.
Old 01-12-2009, 07:00 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
Stock pump should be good for approx. 400rwhp,
Racetronix single kit w/ hotwire should be good for a little over 550rwhp.
I make a double pump kit with Racetronix components that will support over 1000rwhp.
Stock lines should support around 700rwhp.
If you are in need of a system, please give me a call, I stock the Racetronix kits, Double pump kits & also custom line kits
Old 01-12-2009, 08:03 PM
LT1_T/A's Avatar
i have a 396 and had to upgrade the fuel system. got the walbro 255 and bigger injectors.
Old 01-13-2009, 09:09 AM
ss.slp.ls1's Avatar
You have a nice set up man, may I ask how much power you are making?
Old 01-13-2009, 02:45 PM
Next level's Avatar
what size injectors did you get ?
i had 36lbs on mine and it was running to lean.
i also had a stock pump running w/ my 396 for a year.
i'd suggest getting a new pump too.
lonnie ill be calling you soon!!!
Old 01-13-2009, 02:47 PM
ss.slp.ls1's Avatar
Injector calculator...
Old 01-13-2009, 05:58 PM
LT1_T/A's Avatar
lol i wish i knew how much power i am making! i have been trying to get this damn car tuned for the longest....the first time i got it on the dyno my water pump took a ****. the second time it was my fuel pump and injectors. third time fuel pressure regulator. 4th time the regulator i bought was a pos accel, sent it back for an aeromotive. waiting for that to come in. i think it made 320 or 330 running really lean. so to the op, u might as well do the whole fuel system right now!
