rod bolts???
Old 01-11-2009, 11:10 PM
Turd Gen Guy
1nasty86's Avatar
Default rod bolts???
will stock rod bolts on a 5.3 hold 10 psi??? or do i have to upgrade bolts? im trying to do a budget build i can go 8 psi if needed. i want atleast 400 rwhp.
Old 01-12-2009, 01:12 AM
deadhorse66's Avatar
I don't think you'll have a problem with the bolts--its usually the rod that fails, and that is all relative of course to your tune. That being said, they are cheap insurance.
Old 01-12-2009, 02:40 AM
black98ws6ta's Avatar
You should have piston problems before you will break a rod bolt. If your method of boost is decent you will have no problem making well over 400rwhp.
Old 01-12-2009, 04:43 AM
EPP
EPP's Avatar
I agree, we've always seen the stock pistons break first. Bob
Old 01-12-2009, 08:11 AM
pwrtrip75's Avatar
mine holds 15psi plus a 50 shot of spray... 3 years and still going strong.
Old 01-12-2009, 06:44 PM
dman's Avatar
i think RPM is the bolt breaker, not boost
Old 01-12-2009, 06:50 PM
mikef85's Avatar
+1 It would seem the most stress the rod bolts see is the transition from upward motion to downward motion. Thus, rpm's and rod/piston weight would be the issue.
Old 01-12-2009, 07:54 PM
Turd Gen Guy
1nasty86's Avatar
on a 5.3 or a 5.7??
Old 01-12-2009, 08:36 PM
pwrtrip75's Avatar
Originally Posted by 1nasty86
on a 5.3 or a 5.7??
5.3L from a junk yard. Mileage unknown, Im blowing through my current converter running 7500 rpms through the traps.
Old 01-12-2009, 08:48 PM
Turd Gen Guy
1nasty86's Avatar
wow man... lol thats alot of rpm's!!
Quick Reply: rod bolts???
