just to loosen the clamp at the y-pipe/cat. that'll make it easy to rotate the header away from the head, remove the old gasket, clean the two surfaces, put in new gasket & rebolt up.
by looking at it, i need to pull the coil bracket w/coils and access to the rear bolts won't be too difficult. how many foot pounds are you guys torquing your bolts? i think it's around 26 ft lbs.
