LS1 CAR/VETTE Accessories brackets
I’m building a lq4 that’s going in a body dropped air ride S10 and in order to fit it in we switched to a car intake but kept the 317 heads. The intake of coarse doesn’t clear the factory water pump and once we looked the alternator is now like 4 inches to high so we need accessory brackets that keep everything low.
So I need accessory brackets from 97-+ LS1 Car/Vette
Water pump to match NEW or Low miles good shape used..
Sounds like from reading other post i need
Harmonic balancer
Power steering pump also?... This might suck i'm running the hydroboost off the 1 ton on it.
Thanks!
Harmonic balancer
Thanks!
Harmonic balancer
Thanks!
Harmonic balancer
Thanks!
ya let me know we can make a deal on the truck acc. I've got the water pump, power steering pump, brackers etc and even AC compressor (i think we paid 100 for it and MIGHT still try to use it)
sent PM about acc. I just realized i left out the crank pully, harmonic bal.. so let me know if you'll need that because we won't be using it, i might have two spare actually
Still looking for from a camaro/vette...
brackets
waterpump
powersteering
crank pulley/harmonic bal.
Anything else i'm forgetting
brackets
waterpump
powersteering
I've got a harmonic balancer of an '03 vette, pm me. Just so you know, you need to match the balancer to the accessories, the vette pulley is closer to the block than the camaro pulley is.
thanks thorny i wasen't sure if you could mix them or not i haven't seem them up close or heard either way until now. I think the Camaro acc. will work better because the pulled for power steering is sooo close to the steering gear box right now its crazy. And from what i understand the vette setup puts alt ontop like the trucks leaving the big pulley on the ps pump. I might still be interested in Vette stuff let me look into it tonight.
