10 mpg?!
10 mpg?!
Well after I drove about 60 miles, I filled up about 6 gallons. How can I possibly only get 10 mpg? Only mods are cold air and a dumped exhaust. I'm running on royal purple synthetic oil, and my tires are inflated correctly. I can't think of anything else. Should I replace my 02s? I once had a code for one, but it cleared itself...
I started with a full tank and my trip set to 0. I drove 60 miles and then hit the same exact pump. I had about 60 miles on the trip at this point, and it took approximately 6 gallons to top back off.
And you let the pump stop the fill up each time, and didn't top it off manually? Because you can get 1/2 a gallon sometimes by topping it off yourself, and that would be 5mpg difference.
You an automatic? I'm used to MPG in the low teens in my stock 3.23 A4 car.My last tank netted me 11.4mpg,but that's with nearly 100% stop and go,low speed,short distance in-town driving with a heavy foot,though.I'm also pretty sure I'm on original spark plugs and O2's and that gas stations in my area have ethanol blends which can reduce MPG.
I wouldn't worry unless that last 10mpg you got was highway miles with a M6.
Village Troll
In my A4 when I had 3.23s, my MPG was around 15 for town (not stop and go) and highway, on occasion it was 17, but I attribute my crappier mileage to my tune not being as good as it could be.
10 mpg seems a little lower then normal.
I have most bolts ons and 4.10s and still get 24.99 highway and 16.88 semi-city (i say semi city because my commute at the time was 20hwy 4city)
But you can see what a difference four miles of city driving makes.
when i first got my car all highway through an M6 got me 28 mpg when it was stock. now if its combined with bolt ons and no tune i see around 15-16. my O2's are alittle bad tho i think. i had just replaced them before i did my headers and didnt change them back to burn them in
