Parts for Head/Cam swap?
I'm planning to do the head/cam swap by this summer. I try to gather everything I need so I don't have to do the job twice. If there's anything else recommended or mandotary to replace, please post and let me know.
So far I've these parts ready:
Cam/Head (Of course)
7.425 push rod
LS2 Timing chain (maybe go for Rollmaster adjustable)
LS6 Oil pump ported
Water pump
Front cover gasket set
...and what else I need or recommended? Should I do the lifter?
Thanx
7.425 push rod
LS6 Oil pump ported
Water pump
Thanx
Assuming the the heads come with springs, I think you will just need a heads/cam gasket kit (head bolts and gasket, front cover gasket, crank seal, water pump gaskets, and balancer bolt.) and an oil pump o-ring. We have a N-motion single roller chain that is adjustable and reasonably priced. Other than that, you will be good to go! Let us know if we can help at all!
Jon
Jon
Here's my list (I'm doing it soon also) along with GM part numbers (it was in excel so the columns no longer line up), and quantity needed. Also I have a 98, hence the coil brackets.
Heads P/N Qty
V-Cover gasket 12560696 2
Coil Brackets 12563288 2
Head gaskets (pair) 12498544 1
Head bolt kit (1 head) 12498545 2
Valve Cover Bolts
Cam
ls7 lifter set (set of 16) 12499225 1
LS2 timing chain 12586482 1
Timing cover gasket 12558013 1
LS6 Intake
Valley cover gasket 12558178 1
Headers
Header Gasket 12617944 2
Oil Pump
Water pump
WP gaskets 12559271 2
Heads P/N Qty
Valve Cover Bolts
Cam
LS6 Intake
Headers
Oil Pump
Water pump
I got a nice deal on some Comp OE-R lifter (Thanx Lawnboy), even cheaper than LS7 lifter from GMPD so I just go with that. I've think about Cometic. Most likely I'll run stock thickness so if GM MLS is cheaper, I'll just go with that. I need to ask the cam experts (Predator-Z and Pat G) some questions about the head gasket thickness on my setup. So we'll see.
I'll be running TSP 224R with custom port 5.3L head mill to 61cc. It'll be running 11.2:1 so that's the reason why I'll running stock thickness head gasket most likely.
The PN listed above is the GM MLS gasket 12498544. It comes as a pair so you just need to order one. They run about $30. I'm not at work so I can't look up the PN for the lifter trays right now.
