better head?
LS1Tech Premium Sponsor
What short-block are you running?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
You'd have to flycut reliefs into your pistons for clearance with that camshaft and L92 heads. Like mentioned, it's also not my first choice for an L92 headed car. If you're set on the Magic Stick, I'd definitely consider LS6 heads!
__________________
