speed inc flexplate and th400 help
I bought a speed inc flexplate for my th400 trans and th400 3 bolt stall. What else is needed to bolt it up. If it still needs the spacers can someone give me a part number for the spacer so i can order the right stuff the first time.
thanks for your time
you will need the crank adapter to center the converter on the crank. that and you will most likely have to open up the holes on the flexplate a bit. pics here..... https://ls1tech.com/forums/automatic...flexplate.html
