Need to know what color headliner is factory in my car so i can replace it...
That giant list of 3 digit numbers and letters on your drivers door. That's your RPO Codes. There's a website somewhere out there that will run Camaro RPO codes, but damned if I can remember where its at. Maybe you can dig it up on google.
If you happen to have the same RPO code as mine I have your answer. The codes are the 38th and 39th numbers in the set. Mines the lighter of the 2 grays that were available; technically called Pewter.
92B - TRIM COMBINATION CLOTH, MED DK PEWTER (B) (97)
92B - TRIM COMBINATION CLOTH, MED DK PEWTER II/VERY DK PEWTER (01)
92B - TRIM COMBINATION CLOTH, PEWTER (B) (97) 07
92B - TRIM COMBINATION CLOTH, SHALE/PEWTER (B) (97)
92I - INTERIOR TRIM MED DK PEWTER (97)
92I - INTERIOR TRIM MED DK PEWTER II (99)
92I - INTERIOR TRIM MED PEWTER II/VERY DK PEWTER
92I - INTERIOR TRIM SHALE/PEWTER (I) (97)
*edit* and I found your holy grail link. Write down your RPO codes and plug them into this webpage (about 1/2 way down) and it'll tell you everything you need to know about your car. The VIN decoder is in there too.
http://www.camarosource.ca/php/camar...ding&year=1971
Yup, if your ordering from the dealer just give them the RPO color code and/or official name of the color and they should be able to get you all set up. Same should probably work with any other headliner manufacturer.
And if you're looking for a hardtop headliner in Pewter I still have mine laying around from my T-Top conversion if you want it.
Just a quick bit of info then, if you're looking for a pewter colored t-top headliner, they have been discontinued by GM but a light gray one will work and still looks good. We had to do that on Lotus's car.
