Removing shifter knob?? *DELETED*
Re: Removing shifter ****??
For the **** button, yes
To remove it, there is a metal clip like a big staple, facing the radio. Turn car on - do not start it, put the car into low gear, (chock the wheel or set P Brake) and use a small straight blade screw driver or need nose pliers and pull it out. Then pull the **** off.
