Does the Diablosport allow lock up changes?
LS1Tech Sponsor
here's what you can adjust with the U7198 predator, which is the one you'd need for your 1999 firebird...
Timing Table 1000-1800rpm (+/- 20%)
Timing Table 2000-4000rpm (+/- 20%)
Timing Table 4000-7000rpm (+/- 20%)
Fuel Table 2000-4000rpm (+/- 20%)
Fuel Table 4000-7000rpm (+/- 20%)
Idle (+ 500rpm / -300rpm)
Speed Limiters (Trucks Only - already removed in the preset car tunes)
Rev Limiters
RPM Shift Points
MPH Up and Downshifts
Shift Timing
Shift Pressure
Cooling Fan ON and OFF temperatures
Re-Calibrate Speedometer for Gear and Tire Size Changes
Torque Management abuse mode time limit ON/OFF
% torque reduction vs. RPM ON/OFF
Upshift torque reduction (all gears) ON/OFF
Adjust for different injector size
Adjust COT enable temperature
as for the converter lockup speed, you'd have to get a custom predator tune created to adjust that - that can not be adjusted by the end-user via the handheld...
Rev Limiters
RPM Shift Points
Shift Timing
Shift Pressure
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
