Which cam do you think?
228/232 .612 .600 111lsa vs. 233/239 .598 .603 lift. 112lsa
.598 and .603 lift.
which do you think ill get more power out of with the supporting mods in sig?
.598 and .603 lift.
both of these cams should give you good power even with stock heads... What gear are you running? If you are stock 3.42 i would stick with the 228, it have good mid range and top end... it will also be more streetable.
