Timing Chain Dampner 6.0
Old 01-15-2009, 04:32 PM
zx9rgreen's Avatar
Default Timing Chain Dampner 6.0
Does anyone know is the LS2 Timing Chain Dampener 12588670 will work on the iron LQ4/9 blocks?
Old 01-15-2009, 04:51 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
It will work on some...to check, look at the front main journal right above the crankshaft...if it has two holes centered above the crank, that's the two holes for that dampner. If the holes are not there, it wasn't meant to be
There's an image (with my awesome MS Paint skills) that shows in green where the two holes will be.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 01-15-2009, 05:36 PM
Actual pictures here.
__________________
