What do these codes mean?
Old 01-15-2009, 08:19 PM
SSmokin99's Avatar
Default What do these codes mean?
I have 5 codes that I'm throwing and they are P0102, P0134, P0141, P0801, & P0803. What are they?
Old 01-15-2009, 08:51 PM
poolshark021's Avatar
http://gearchatter.com/
Old 01-15-2009, 08:55 PM
transwiz's Avatar
p0102:Mass air flow(maf)sensor circuit low frequency. p0134:H02S circuit insufficent activity Bank 1 Sensor 1. P0141:H02S heater performance Bank 1 sensor 2 . I got this info from the GM service Manual f body 2000 book if it helps.
__________________________
2000 t/a ws6 with lots of mods
Old 01-15-2009, 08:59 PM
transwiz's Avatar
Also P0801: Reverse inhibit solenoid control circuit. P0803:Skip shift solenoid control circuit.I hope this info helps you.
Old 01-15-2009, 09:23 PM
2xLS1's Avatar
Your Eng Sens fuse is blown.
Old 01-16-2009, 12:15 AM
SSmokin99's Avatar
My engine sensor fuse is blown? How did that happen? Also, what will the effects be from this?
Old 01-16-2009, 12:35 AM
SSmokin99's Avatar
Old 01-16-2009, 09:55 AM
2001NBMZ28's Avatar
Yep, I'd guess ENG SEN fuse too - the MAF, 02's, skip shift and reverse lockout are all on the same circuit. If you have LTs look for a burnt/melted 02 harness.
Old 01-18-2009, 09:24 PM
SSmokin99's Avatar
Well I had to drive about 40 mins to an exhaust shop on open headers so do you think that could've messed up my O2's? Also, I checked all my fuses with a multimeter and ALL my fuses are working fine.
Quick Reply: What do these codes mean?
