Cadillac CTS-V - motor transplant questions
burnin red
01-15-2009, 08:53 PM
can i switch the engine from a 2001 z06 and put it into my 2004 ctsv and put the cadillac engine in the corvette???
besides the bolt on parts on the front would there be any differences?
the z06 engine is built to the hilt and the v engine is bone stock, and i want to keep the v and sell the z06. any thoughts would be great.
XtraCajunSS
01-15-2009, 10:06 PM
That one's easy. Yes, they will swap no problem whatsoever.
Shane
raven154
01-15-2009, 10:43 PM
+1 ^^^
Its the same block, it will bolt in without a hitch.
jerrad
01-15-2009, 11:42 PM
Raven, your from Claremore? I'm a Pryor guy myself. Moved to Texas about a year ago.
Back to the thread, make sure you swap all the pullies, acc, etc. Also, put some good motor mounts in there while you're at it.
raven154
01-16-2009, 04:43 AM
Yeah by some UUC mounts. The stock ones are trash.
@jerrad
Yeah I've been in Claremore for 24 years! JUst recently found a girl though so may be moving around. Haven't decided yet.
Thread jack over.
JonCR96Z
01-16-2009, 11:26 AM
I've got a full set. Poly motor and tranny mounts 385 shipped.
STAGEUP
01-16-2009, 12:16 PM
I think you will also have to swap the oil pans
burnin red
01-17-2009, 05:44 PM
cool thanks guys good to know before i start this project that it wall all work out
scatillac
01-17-2009, 06:33 PM
Besides the oil pan/windage tray/pickup tube, you will also have to change the pilot bearing to the CTS-V (or 99-up truck) pilot bearing.
Also, if you use the Corvette clutch/flywheel assembly instead of the V's stock clutch/flywheel, a clutch slave spacer from TPIS or Katech will have to be used to retain the proper clutch pedal operation.
burnin red
01-18-2009, 02:51 PM
anything else you guys can think of?
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
