steering shaft removal?
Old 01-16-2009, 12:16 AM
vettett15's Avatar
Default steering shaft removal?
Hey guys,
whats all involved in removing the steering shaft? Do I just need to do the top and bottom bolt and then pull it out?
thanks,
pete
Old 01-16-2009, 01:54 PM
nemss1's Avatar
remove the nuts to the brace that hold the steering shaft to the dash
remove the 3 bolts on the interior firewall
remove the 11mm nut on the shaft in the engine bay
to pull the column all the way out, remove the steering lock/cable
