My New KTP turbo kit .
Hi all ,
Hear is a few pic for my new set up the headrs the DP and the cross over pipe josh @ KYTP did good job on it and i like the way he did the set up and it has alots off roon for the spark plug wire and spark plug to , and thanks to chuck @ burckhart chassis for the grait work that he did for me .
Hear is a link for the turbo set up .
http://good-times.webshots.com/album/569332053ScRmFW
and hear is a vid for the last month in track with old set up
http://www.vimeo.com/2848315
and hear is few pic for the parts that i got from chuck .
Hear is the FI98X head unit .
hope all will be soon hear so i can have it ready for the next race .
enjoy it .
enjoy it .
that's one hell of a nice hotside.
if you don't mind me asking, you can PM me if you want, but I'm really curious to know how much a hotside like that would run me. I had to let ya know that it's beautiful work and people will be in awe when they see it in person. are you getting those pipes coated?
what size is your radiator? i'm also running meizere's rad. mounted WP setup, but i'm having a hard time keeping it cool while street driving. the dimensions of mine match meizer's website. 22x14x2, but your radiator looks beefier then that.
Its a race setup guys. It was not built with intentions of Fuel Economy, A/C, streetability, P.S. or anything other than making POWER.
The goal was simple. Dont burn plug wires and fit a 5" DP in there. Even with the BMR Turbo k-member it is tight. 4" falls in. 5" is tight.
I wont discuss pricing as per the rules of the site. I will try field answers to the technical questions that I can.
Passenger header
Driver Header
Engine shot
Pre WG engine shot
WG pipes ran
Finished hot side Engine shot
Passenger header
Driver Header
Engine shot
Pre WG engine shot
WG pipes ran
it was fast but i was having problem with the converter that i got i was runing 9inch caon bolt togather and right now i just got the neal chance converter 10 inch hope it will hold .. for all the parts that i got its around 15000 from burkhart chassis and the turbo set up , there is alot more parts need to be install .
Thanks, a hot side like that it will be good for 2000+ HP and josh really did got job on it i like the way he did the headrs and every thing like i asked .
no am not going to get them coated because i dont have time to wait i race at the end off the month .
my that i got from chuck is 16x24 and am also runing meizere's pump on the rad . mine is going to be just for drag racing no street . you can call chuck and he will give you all the info that you need from that set up .
