opti question
Old 01-17-2009, 09:58 AM
impalaSS's Avatar
Default opti question
anybody have a link to a write up or tell me how you can use the opti on an lt1 when using a carb
i totaled out my 383 caprice so i'm putting it in something else and if i can run an opti then i can shove the motor back more
Old 01-17-2009, 10:24 AM
96capricemgr's Avatar
The opti is totally dependant on the computer to command the actual timing. Is not like an HEI where it is physically set, going to need a computer of some sort to control it and that computer will need TPS and MAP inputs. In the end it might be easier to consider keeping the injection. That r deal with the fact you need a rearmount distributor.
There are other alternatives but the price goes way up.
Old 01-17-2009, 02:02 PM
schwoch1's Avatar
Why not keep the injection????? I am SOOOO glad that I did not listen to everyone elses opinion when I shoved the LT1 in my GMC and kept the EFI!!!
Just a thought!
Mike
Old 01-17-2009, 09:27 PM
impalaSS's Avatar
Just a thought!
Mike
its gonna be an all out drag car
Old 01-17-2009, 11:15 PM
schwoch1's Avatar
Gotcha, use a crank trigger and a front mount distributor, or the DIS setup from ELectromotive, neither one needs the distributor in the rear. The opti is heavily relaint on the ECM!!!
Good luck!!
Mike
Old 01-18-2009, 08:44 AM
tomcowle's Avatar
You can run a crank trigger/msd box and a gutted opti. Pretty simple set-up that works.
Quick Reply: opti question
