new 4l80e install what rear gear to run
Old 01-17-2009, 12:45 PM
turbo kid's Avatar
Default new 4l80e install what rear gear to run
Hi,I have just installed a 4l80e trans into my old street rod.The motor is a 04 ls1 with twin turbos and the converter is a yank sc3000.The rear gear is a 373 and was wondering what others run for a gear on a STREET CAR?I will drive it 95% of the time on the street with the a/c on but still want to have some *****.I was thinling a 307 gear.The od trans has a steep first/2nd gear so I think it will have a nice hole shot on the street and still have some highway mileage right???
Old 01-17-2009, 04:51 PM
forcd ind's Avatar
the 4l80e only has a 2.48 first gear, so i think it would be better with 3.73's
if the converter was built for the ex gears, changing them will affect the stall
i run 3.73's with a 28" rear tire
Old 01-17-2009, 05:47 PM
Closed ex-Sponsor Account
tptransmission's Avatar
It also depends on what you engine torque curve looks like. I would leave the 373 for the launch since you are running the factory 2.48 ratio first gear. Especially if you use it a a daily driver.
Old 01-17-2009, 06:25 PM
calongo_SS's Avatar
I'm running 3.73's in my twin turbo LS1 4L80E camaro with a PI 3600 stall. Converter is a little loose, but no complaints other than that.
Old 01-17-2009, 08:48 PM
RamAir02TA77's Avatar
I just ordered a 9'' with 3.89's so we will see how that works out with the py3600 and the spray outta the hole that 2.48 sucks but im hoping by switching from 3.23-3.89 it will make a nice different outta the hole.
Old 01-18-2009, 03:43 PM
turbo kid's Avatar
The motor is all stock except good valve springs and the twin turbos.I do want to get on the expressway and go across a few states to the goodguys rod runs with the car with the ac on and get some mileage.What rpm s do you guys turn at 70 mph?Please?
Quick Reply: new 4l80e install what rear gear to run
