Vacume line from pass side tb to pcv
Old 01-18-2009, 06:10 AM
FL-LS1's Avatar
Default Vacume line from pass side tb to pcv
This line that has a funny shape end and goes to the pas. side of the tb then back along the tope of the valve cover was cracked and leaking air. It is a short 90 turn, the parts store didn't have it so I just used some regular hose is that ok?
Old 01-18-2009, 11:42 AM
Formula413's Avatar
Are you talking about the PCV valve? You can't just replace it with a piece of hose if that is what you are referring to. Can't you snap a pic just for clarification?
Old 01-18-2009, 11:55 AM
jsteele90's Avatar
yes your repair is fine.
