Help w/efi live usb driver for 7.5
Old 01-18-2009, 06:58 AM
slowec's Avatar
Default Help w/efi live usb driver for 7.5
Once I updated my software to 7.5. I can't figure out how to make my computer take the usb driver download. My laptop won't pop a window when I plug in the V2 into my laptop.
Any help would be great. Thanks...
Old 01-18-2009, 07:17 AM
TAQuickness's Avatar
I'm a fan of clean install's over upgrades. You might try removing the software and re-installing. You could also send a note to support@efilive.com or post/search their forum http://forum.efilive.com
Old 01-18-2009, 07:23 AM
macca_779's Avatar
Run FTClean to remove the USB drivers and then plug your V2 back in. It will then reinstall a fresh version of the drivers.
FTClean here:
http://www.ftdichip.com/Resources/Utilities/FTClean.zip
Old 01-18-2009, 08:05 AM
Black02SS's Avatar
I agree with macca, BUT be careful... If you have other programs that use the same FT drivers, they will be erased as well. I have done this countless times and have never had an issue.
Old 01-18-2009, 02:53 PM
ringram's Avatar
Probably had the old drivers installed still so didnt need to prompt you to change.
If you go into device manager when its plugged in does it show under usb devices?
Can you look at the licensing info on the unit from the software?
If so, then your cool dont worry about it.
If you really want new drivers just go into the device in devicemanager, assuming its showing up and click on update drivers and browse to where the new install was to pick up the new drivers.
Old 01-19-2009, 08:22 PM
joecar's Avatar
Hi everyone...
More info: http://www.fishtuning.com/downloads/...and_I_cant.pdf
Old 01-20-2009, 10:22 AM
slowec's Avatar
Originally Posted by joecar
Thats what I needed. Thanks soooo much!!!!
I am back in the game.
