Rod bolt install ?
Rod bolt install ?
Do the rods need to be resized when converting to ARP rod bolts? If so, why? I figured you could just tap out the stock bolts and pull the new bolts through. I've never done rod bolts before, just your budget refresh on older sbc. Thanks
The correct way is to have them resized. Getting the bolts in/out can cause some distortion. That being said, have there been people that swapped bolts and not had them checked? I am sure the answer it yes.
I've never heard of Distortion, I've never had a problem with anything and I have taken Engines down.
