Grant wheel install
As long as you understand that you'll be sacrificing your air bag, it's not that hard. You'll need a Grant 3196 adapter, and a steering wheel puller (which you can rent from Advance Auto). You will also need a pair of snap-ring pliers.
Start off by disconnecting your battery, and I think I pulled the air bag fuse too. There are two hex bolts on the back of the steering wheel that hold the airbag on, unscrew those, unplug airbag, and set aside. Remeber to start breathing again now. Gently push and turn the horn connection and it will come free. Use a 21mm socket to take the steering shaft bolt off, and then use your steering wheel puller to remove the wheel. The next steps are debateable; Some people just cut wires, others remove the snap ring, pull out the Cancelling cam, and find a connector somewhere to unplug. Once that's said and done, follow the instructions that come with the steering wheel/adapter, and you're golden. To hook up the horn, tie both of the wires together and connect them to the horn button, and then run a ground wire from the second horn button connection to one of the bolts that holds the wheel on. As an added note, your airbag light on the dash will now be lit, when it bothers you, you can take the bulb out, tape over it, or paint the bulb with hi-temp black paint.
Thanks DR..Thats a pretty good write up. You mention the cancelling cam, what does that do? Have to do with the air bag?
I had planned to pull the gauge cluster and remove that bulb..I have a few others to remove also
Do you have a pic of yours?
No pics I'm afraid, I can't remember if the wires running to the cancelling cam were related to the airbag or the steering wheel audio controls. The cancelling cam itself is the device that turns off your turn signal when your wheel turns back to center, it just has other stuff attached.
There's another guy on here who has done this recently to his own car, I'll see if I can get him to chime in. It has been a number of years since I've been up close and personal with the innards on one of these cars.
My advice is plug the hole in the cluster with something so you will not see the light.
PS most those bulbs are board mount leds.
