PP S2 Heads, TSP 228R, Pacesetter LTs = DYNO result
Old 10-04-2003, 05:32 PM
bill99hawk's Avatar
Default PP S2 Heads, TSP 228R, Pacesetter LTs = DYNO result
I went to the dyno today and ran 391 RWHP while running very LEAN (15s). I am guess I should easily break the 400s, more like 420, when I get the PCM fuel tables tuned. I am still using the stock ls1 intake too, so a few a couple more mods should put me around 450 RWHP. Thanks to Chris (Whistler) who did all the mechanic work, both Jason at TSP and Terry at Patriot Performance for providing great customer service. Can someone please look at my TQ curve and give me a reason to why the graph is all of the place.
Old 10-04-2003, 05:36 PM
gomer's Avatar
Default Re: PP S2 Heads, TSP 228R, Pacesetter LTs = DYNO result
Great numbers, but PLEASE richen that car up some before running it to WOT again.. that is REALLY REALLY lean. You'll pick up some good power with the correct tune.
Old 10-04-2003, 05:43 PM
Cliff98Z's Avatar
With a tune your going to pick up a good amount of power.
Old 10-04-2003, 05:49 PM
SSactionLs1's Avatar
rule of thumb
lean - more HP
rich more Tq
13.7 is considered perfect for power
Old 10-04-2003, 05:53 PM
SScam68's Avatar
A/F ratio
gomer's Avatar
too lean = knock retard and loss of power..not to mention those nasty increased combustion temps that degrade your engine.. 12.9 is what you need to shoot for
Old 10-04-2003, 05:58 PM
The Dragon's Avatar
Ditto. 12.8 to be cautious. A 13.7 or higher afr with a high dyno # don't mean jack if the motor goes boom FWIW.
Old 10-04-2003, 06:29 PM
98TAauto's Avatar
i;d go 12.9 at peak power for safety... man you have a tidle wave type graph.. its a big jump around peak power from nowhere. IOnce you get her tuned in she will be in the 410-420's im sure
Old 10-05-2003, 01:17 AM
Sawzall and Welder Mod
Whistler's Avatar
With a pulley, LS6 intake and some PCM editing there is an easy 30 horespower to be gained.
Old 10-05-2003, 06:55 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Wow man be careful with air fuel like that!! I'm glad your happy with the setup though, your running that cam on a stock tune? Nice #'s though!
You really need to get that thing tuned so we can see what she's really doing.
If you need a ls6 intake drop me a e-mail, I have a few left at the 365 shipped price
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 10-05-2003, 08:51 PM
CHRISPY's Avatar
Yep dont hammer the car with AF that lean. Richen it up to around 12.8:1 at torque peak and 13:1 at RWHP peak. Different setups like different AF's so you may need to play a bit.
Cheers,
Chris
