General Maintenance & Repairs - odd electrical problem
View Full Version : odd electrical problem
SuperSlow02
01-18-2009, 04:13 PM
My car sits most of its life and the other day I decided to drive it. Well after about a block my shift light flashes back on and all my gauges do a sweep, like i just started the car or something, the engine didnt loose a beat or anything..just the radio and gauges. Well it seems to do it at least once when I drive it. Also another weird thing is when I try to unlock the car with the remote it wont respond but when I unlock it and get in ive seen the gauges do a sweep without putting the key in:confused:. Now normally Id just figure maybe the battery in the clicker is dead, but I can lock the car and unlock the car once ive driven it...........Im hoping maybe its a crappy battery connection, the positive had some corrosion on the threads so I cleaned it. Havnt had a chance to see if that helped yet. Anybody else have any clues as to what the hell is going on with it?
SuperSlow02
01-19-2009, 02:06 PM
no ideas...anyone?
nemss1
01-19-2009, 02:53 PM
check battery, connections, and alternator
beezer1519
01-19-2009, 05:34 PM
when you check the battery connections check the main hot going to the fuse boxes in the engine bay mine was doing the gauge sweep/ gauges off thing and that's appereantly what the problem was
SuperSlow02
01-19-2009, 05:48 PM
Ill take a look at it, was it crroded inside or a bad connection?
Arc00TA
01-20-2009, 04:18 AM
Corrosion on the battery terminals. The car will run fine off of the alternator once it is started but it may cause wierd indications. That or a bad battery. Have it tested for free at an auto parts store.
