Trickflow guideplates causing my pushrods to not be straight?
Old 01-18-2009, 06:19 PM
BlackLT1Z's Avatar
Default Trickflow guideplates causing my pushrods to not be straight?
Check out the picture. The left side pushrod is straight on all cylinders. The right hand side is leaning. They are all like this. Could it be the guideplates don't line them up properly?
Old 01-18-2009, 06:42 PM
robsquikz28's Avatar
are they leaning on the guideplate themselves or not???? if there not hitting anything then i would say kinda normal but i dont have block in front of me to see if its jacked up or not....
need more peeps to post i can def. be wrong
Old 01-18-2009, 06:48 PM
BlackLT1Z's Avatar
Yes... they are touching the guideplates.
Old 01-18-2009, 07:26 PM
96capricemgr's Avatar
Isky adjustables.
How are the rockers centered on the valves???
Sure folks recommend the Trickflows, but that does not necessarily make them right, I have not handled them but I have learned popularity does not make right.
Old 01-18-2009, 07:41 PM
BlackLT1Z's Avatar
The rockers are perfect on the valve. They have a good pattern. I read on CZ28 that it was ok. I'm assuming they are fine... haha
Old 01-18-2009, 08:27 PM
tylert14's Avatar
If everything lines up it's alright if they lean. If something is not lined up you can cut the guide plates in half and line everything up and weld the guide plate back together.
Old 01-18-2009, 09:02 PM
Low N Slow's Avatar
The Trickflows didn't work on mine. Isky adjustables are the way to be sure.
Old 01-18-2009, 09:35 PM
BlackLT1Z's Avatar
Now I'm pissed. I don't like the way that looks. I'll have to get the Isky guide plates.
RamAir95TA's Avatar
I used the GM hardened guideplates and they line up perfectly.
Old 01-18-2009, 09:38 PM
BlackLT1Z's Avatar
You wouldn't happen to have the part number for those would ya?
Old 01-18-2009, 09:43 PM
RamAir95TA's Avatar
That's the p/n for ONE, so you need 8.
Old 01-18-2009, 11:27 PM
BALLSS's Avatar
As suggested, get the ISKY "adjustable" ones. Leave rocker studs lose enough to slide them so the RR tip is CENTER on the valve stem then tighten the rocker studs. You "may" have to grind the ISKY ones or spread them apart.
The GM guide plates I did have were not "hardened" and did wear from the hardened push rods. The GM ones are one piece and like all one piece guide plates do not allow single RR adjustment from side to side.
After the ISKY's are installed you can tack weld them togeather...but I did not and they have been stable for years.
Old 01-19-2009, 12:15 AM
Village Troll
SS RRR's Avatar
Welcome to the world of the Small Block Chevy...
Old 01-19-2009, 12:18 AM
SoxXpupPeT's Avatar
hmm what part # are those guideplates ? when i installed mine they seemed to go in fine. they werent hitting the head or anything and the rockers were pretty lined up. but i didnt have my intake off for any of that
Quick Reply: Trickflow guideplates causing my pushrods to not be straight?
