Manual Transmission - McLeod Single Disk slipping on high rpm shifts, is it toast?
verbs
10-04-2003, 08:02 PM
I've had the clutch in for roughly 20K-25K miles or so, and as of late, the clutch isn't grabbing right away when I make super quick high RPM shifts in race situations. I'm literraly outshifting the tranny. I upshift it and let off the clutch quickly, but then there's a bit of a lag from when I make the shift and let off the clutch until the car starts accelerating.
Is this a sign that the clutch is done for? I have probably around 40-50 6500-7000rpm clutch dumps at the track, and lots of abusive driving. :burn:
Nine Ball
10-08-2003, 11:20 PM
Yep, that disk is toast :D
Been there, done that, many times!
35th SS
10-09-2003, 03:38 AM
better get the twins next.
verbs
10-10-2003, 03:37 PM
Can I just buy the twin disks and put it in the single disk clutch housing?
66ImpalaLT1
10-10-2003, 03:41 PM
Nope, I think they're totally different.
SMOKIN01TA
10-10-2003, 04:26 PM
had the same problem, its fried
vegasta
10-10-2003, 08:57 PM
can the single disc be rebuilt? so that you dont end up paying 800 bucks but less to replace whatever is "fried" lol as I am considring getting this clutch.
verbs
10-11-2003, 12:19 PM
I'm told no it can't be rebuilt, and the worst part about it is McLeod doesn't sell the clutch only.
You have to buy the entire package which I already have.
I think my only bet is to go with a stage 3 Spec.
66ImpalaLT1
10-11-2003, 01:08 PM
Have you considered a Ram clutch? I have heard they will rebuild them, surface and balance PP and flywheel, for a small fee.
I just bought their VDS system with aluminum flywheel, sintered iron disc and 402 pressure plate. Installing it next week.
Eric
383ss
10-12-2003, 07:21 PM
shit, my twin disc is doing the same thing :(
vegasta
10-14-2003, 05:49 PM
Eric let me know how the clutch feels etc.. I might opt for a RAM VS a Single disk kevlar as theram is rebuildable from what I seee?
verbs
10-20-2003, 02:15 PM
I think I found out a way to check for clutch slipage....
I was told that if I change the A/F ratio section on the bottom of my dyno graph to MPH, I can see if the clutch is slipping.
Supposedly the MPH line on the bottom of the dyno graph should be a straight line (at an angle) all the way to the redline. If the line isn't straight and I'm seeing dips/drops in the mph line, it's a good sign of slipage.
Can anyone confirm this?
