Will an LS1 rear fit on my 97 Formula?
Old 01-18-2009, 10:32 PM
koolaid_kid's Avatar
Default Will an LS1 rear fit on my 97 Formula?
I guess I would use the backing plates already on my car?
Thanks.
Old 01-19-2009, 01:07 AM
In-Zane Moderator
ZONES89RS's Avatar
All swaps out.
Old 01-19-2009, 02:06 AM
96lt1m6's Avatar
This is a very straight foward swap. however, do yourself a favor and be certain to get the emrgency brake cables,cable brackets and the rear brake lines and distribution block which is fastened to the top of the rearend a big bottle of brake fluid(i use synthetic).....be safe use a good jack and good jack stands
Old 01-19-2009, 08:42 AM
shbox's Avatar
You cannot mix the backing plates/brakes and axles. IOW, if you use the LS1 axles, use the LS1 brakes.
Quick Reply: Will an LS1 rear fit on my 97 Formula?
