hey time for an oil change
Old 01-18-2009, 11:03 PM
PontiacSpeed91's Avatar
Default hey time for an oil change
my car just hit 72k and im getting ready for an oil change (synthetic) any recommendations? as well as the filter? other things i should look into working on as well? Thanks!!
Old 01-18-2009, 11:47 PM
elias_799's Avatar
royal purple 5w30 and a k&n oil filter. good luck
Old 01-19-2009, 05:27 AM
SuperSport01's Avatar
Amsoil 5w-30 and a WIX oil filter.
Old 01-19-2009, 06:12 AM
Joshiedoom's Avatar
pennzoil platinum 10w30 and a k&n filter..
the best bang for the buck
do some UOAs
Old 01-19-2009, 06:50 AM
99_Z28's Avatar
Castrol syntec with a K&N filter...
Old 01-19-2009, 08:05 AM
LS1-450's Avatar
do some UOAs
Agreed, Pennzoil Platinum is the proven "bang for the buck" oil for the LSX tested on BITOG & here via UOA's. Although, I would suggest 5w30 even @ 72k miles.
Amsoil is also an excellent oil. It just costs more.
Old 01-19-2009, 09:47 AM
SS1875's Avatar
Guess I'm old school, I still use Mobile 1 5w30 and a Delco filter as per my engine builder.
Old 01-19-2009, 12:42 PM
deadhorse66's Avatar
Nothing wrong with that--its what I use too, and as far as I'm concerned you can't really do better. Most everything already mentioned is as good, but you won't catch me calling it any better.
Old 01-19-2009, 01:46 PM
Johnnystock's Avatar
I've tried Mobile and Penzoil...nothing wrong to say about the 2..
Old 01-19-2009, 01:48 PM
OnyxY2KSS's Avatar
Here we go again... page 1...
I recently switched from M1 to Penzoil platinum. K&N filter is great because it has a 1 inch socket fitting on the bottom for easy install/removal. That is all.
Old 01-19-2009, 02:43 PM
Arc00TA's Avatar
I recently switched to the new M1 0W-30 stuff and it is excellent. Once I hit like 2k miles I'll probably spring for a UOA and see what it looks like. I use either K&N filter or AC Delco depending on where I buy it from.
Old 01-19-2009, 03:20 PM
56chevyboy's Avatar
well if your in florida weather is always pretty warm so you can run a 10 weight over a 5 weight. amsoil, royal purple, mobile are all good oils and k&n filters
Old 01-19-2009, 08:35 PM
elias_799's Avatar
royal purple has been proven to give you more power because of less friction. if you look on websites the only people that talk **** about royal purple are amsoil representatives.
Old 01-19-2009, 08:41 PM
HavATampa's Avatar
lol....almost every brand of oil has been posted in the first 10 posts. This question is about like asking what's the best cam to buy. The answer is always whatever is running in the car of the person posting the answer. Just use a high a quality oil and filter with the correct weight and change it every 3-5000 miles. Don't lose any sleep over it and don't go broke doing it.
Old 01-19-2009, 08:46 PM
domestic disturbance's Avatar
like he said
Old 01-19-2009, 10:43 PM
SOMbitch's Avatar
Your rear Diff fluid is supposed to be ghanged every 30K. Go to GM and buy a gasket and a bottle of additive and pick up the fluid from your local AZ,AA, NAPA or wherever
Old 01-20-2009, 01:00 AM
Thank you very much for your responses! Think im going to go with the Pennzoil 10w-30 with a K&N.
now, I've had the transmission fluid changed, anything else? hows about a radiator flush?
Old 01-20-2009, 09:37 AM
TXZ28LS1's Avatar
been happy with castrol syntec and a regular AC DELCO filter!!
