Idle Problem
Idle Problem
i have a 2000 camaro z28, today i was pulling onto the road, gave it a little gas, car took off, then started sputtering, then engine died, i coasted off the road, car didn't want to start, finally got it started, i have to hold the gas about half way down to keep it idled, and running, once i let off the gas the car dies.... Any ideas ?? Please help this is my DD
Fuel pumps do fail slowly sometimes and not all at one time. Does it prime when you turn your key to the "on" position?
If it starts the pump is working at some level. I'd lean more toward a dirty fuel filter or injectors, but you never know.
Howl ong has it been since you changed the filter?
No SES codes? A failing Crank Shaft Position sensor can do that to the engine too. Get a scan for free at Advance Auto or PepBoys.
changed fuel filter in july, i can hear the pump priming, a buddy came over, and we can hear a noise at the engine, i'm going to check the push rods, valves tommorrow morning
Pulled the valve cover, found a valve retainer or "keeper" came off #4 , pushrods look fine, rocker's look fine.
Just ordered the keepers 0.19 cent part is holding me down
Pulled the head, had a bent valve, replaced the valve, also had a bad lifter. All is good !!!! Before, the car had a knock to the engine... and it's GONE... Sounds beautiful
