Anyone ever have trouble installing a crankshaft sprocket?
Old 01-19-2009, 09:41 PM
I8ASaleen's Avatar
Default Anyone ever have trouble installing a crankshaft sprocket?
Ok I bought a double roller chain for this car and now the cam sprocket doesn't line up with the bolt holes. WTF! What double roller timing chain do you guys use??? We got the crank sprocket on and noticed that the bolt holes are skewed...
Thanks for everybodies input in the earlier thread, I'll have pics of the mild build once we get everything up and going.
Old 01-19-2009, 09:58 PM
shbox's Avatar
Darn, you could not get it off, now you can't get it installed? Use some oil on the crank and make sure it is clean. A length of pipe will work for an install tool.
Old 01-19-2009, 10:10 PM
I8ASaleen's Avatar
Yea, we got it on just a few mins. after with alot of hammering. Alot of hammering...hammering. It's just now the camshaft bolt holes don't line up and it seems like its completely off b/c the inner diameter of the other sprocket was smaller than the one I have. Back to the Napa.
Anyone else know of a timing chain that will fit?
Old 01-20-2009, 12:23 AM
2XR95Z28's Avatar
i Have a cloyes double roller i got from Advanced Inductions when i bought my cam kit, i can check the box tomorrow for a p/n if you need it?
Old 01-20-2009, 06:51 AM
shbox's Avatar
Sounds like they gave you the wrong parts.
Old 01-20-2009, 09:14 AM
fergymoto's Avatar
They may have given you a timing set for a flat tappet cam.
Old 01-20-2009, 10:31 AM
I8ASaleen's Avatar
could be. What should I look for?
Old 01-20-2009, 11:08 AM
shbox's Avatar
First thing you would notice about the cam gear are the teeth on the backside that run the water pump. Just make sure you get an LT1 set for 95-97s (since your sig says 97).
Old 01-20-2009, 02:21 PM
I8ASaleen's Avatar
Yea, I was just trying to get a double roller set that would fit my cam b/c I deleted the waterpump drive and I didn't like how loose the stock one was.
Old 01-20-2009, 05:43 PM
I8ASaleen's Avatar
Anyone have a P/N for a Cloyes double roller timing chain that will fit 95-97's?
Old 01-20-2009, 11:16 PM
shbox's Avatar
Originally Posted by i8asaleen
anyone have a p/n for a cloyes double roller timing chain that will fit 95-97's?
9-3145
Old 01-21-2009, 01:10 AM
I8ASaleen's Avatar
Sweet! Gotta find one in a few days now...
Quick Reply: Anyone ever have trouble installing a crankshaft sprocket?
