4L80E Transgo -3 FMVB line pressure ?
So I installed my 4L80E after installing the kit, with the vacuum modulator disconnected I have the following line pressure.
Park: 150
Reverse: 250
4th: 100
1st: 150
This is with the driveshaft removed so the transmission can freewheel.
No strange noises, no leaks, no whining (at least nothing I can hear)
Comments? I was expecting more line pressure in 1st when the vacuum modulator was unhooked. Tomorrow I will put a mighty-vac on it and see if it responds at all to vacuum.
Also, with the stock pan & stock converter, how mush fluid from from totally dry? My car can't use a stock dipstick because the engine is set back too far.
Thanks
Craig
Craig
Park: 150
Reverse: 250
4th: 100
1st: 150
Thanks
Craig
Craig
