max rwhp of svo 42lbers
Old 01-19-2009, 11:27 PM
98mysticZ's Avatar
Default max rwhp of svo 42lbers
just like it says i have a 408 making 484/462 n/a and was going to put on a 200 wheel dry shot... do u think i will be maxing them out?
Old 01-19-2009, 11:43 PM
WS6RED2002TA's Avatar
You would be close to max them out. I would go with 50# injectors. That should keep you safe.
Old 01-19-2009, 11:59 PM
ItsNotStock's Avatar
My friends NA 427 42# were around 80%. I would re-think a wet shot (stand alone) or bigger injectors.
Old 01-20-2009, 12:19 AM
405HP_Z06's Avatar
Based on my calculations, you will need a 50 lb/hr @ 3 bar injector running 4 bar fuel pressure. Check with FICINJECTORS <sponsor>, they have great prices and service. You woud be near 95% DC with the 42's.
Calculation:
Old 01-22-2009, 11:52 PM
Flaco's Avatar
i'm running a 414 and made 560 rwhp N/A at 85% injector duty cycle @ 7500 rpms
42lbs svo
Old 01-26-2009, 02:03 PM
koolrayz's Avatar
I was running a 200 dry shot on a 408 that made 525rwhp on motor. With one walbro fuel pump, the regulator at the rails. I was maxing out 60# injectors. (90% duty cycle) at 7000 rpm. one walbro will really only feed 50# of injector.
Hope this helps
