Powersteering pump questions
Old 01-20-2009, 07:42 AM
RsSean's Avatar
Default Powersteering pump questions
This may sound a bit confusing. I want to remove the power steering rack and go to a manual rack. The tricky part is that I want to keep the power steering pump on the front of the engine. Looks and orginality. Is there a way to cap or close off the pressure line, and also the return line? IS that possible? The engine bay will look stock but under neath the car will be a manual rack.
Old 01-20-2009, 09:40 AM
dutinsss's Avatar
i think it would be possible, but why? having a manual rack isn't really something worth hiding IMO. and you'd still be keeping the weight of the pump and the drag of the belt turning it.
Old 01-20-2009, 12:43 PM
zman1969's Avatar
Default P/S pulley options
look here:
https://ls1tech.com/forums/generatio...te-pulley.html
looks like to me you can have them make one for you or do the short belt
good luck
Old 01-20-2009, 01:46 PM
03Sssnake's Avatar
little off-topic.. I have thought about going to manual rack. Any caveats for a DD or should this strictly be for a track car?
Old 01-20-2009, 02:03 PM
RsSean's Avatar
Originally Posted by zman1969
look here:
good luck
Thanks for the link I was looking for something like that.
Some people run them on the street and some run them on the track. It is a pain to turn the wheels sitting still, but then again why would you do that in the first place. I am going to a manual rack cause I am tried of fooling with my powersteering rack whining, leaking, squealing, tried of pump leaking, line dry rotting, and so on and so forth. To me that would solve a lot of childish games for me. BMR sponsor or one that carries BMR stuff has them for a real good price.
Old 01-20-2009, 04:01 PM
03Sssnake's Avatar
thank you for info
Old 01-20-2009, 04:03 PM
Gen414's Avatar
Well, unless yo have "skinnies" upfront, manual steering on a DD can become a pain in the ***. Especialy if you do alot of in town drving, parallel parking, etc... I mean, it all depends on what you can put up with.
Old 01-21-2009, 09:19 PM
dutinsss's Avatar
i'm still wondering why you don't just get a shorter belt and take the pump off. what's the point of having the dead weight of the pump or paying extra for a delete pulley?
Old 01-22-2009, 07:35 AM
RsSean's Avatar
Because it is on my friends non LS powered camaro. PITA to find a pully delete for it and not run into belt issues. Looking at teh Katech PS delete pully to see if that will work.
