ls2 oil presser sensor
I've never heard of it having a Temp Sensor built into it, unless that is for Oil Temp..
I figure the middle wire would be your signal wire like the single one on the LS1 Harnesses, but I could be wrong.
I hope someone has some insight to this as well, cause I would like to know.
It is much bigger, and the raised part of the valley cover only makes it taller. It looks goofy but it works. I called TSP about this when I was dealing with it, they said it is a direct swap
