cruise control question
Old 01-20-2009, 03:24 PM
broke again's Avatar
Default cruise control question
new to the ls scene but just finishing up a turbo install on my 2000 camaro. the air cleaner and intercooler to manifold tube go through the area in the driver side fender where the cruise control is mounted. it would be so much easier to delete the cruise control box instead of relocating. does anyone know if the box only handles the cruise control function or does it interface with other aspects of engine/electronic management?
thanks in advance,
eddie
Old 01-20-2009, 06:27 PM
Floader's Avatar
Originally Posted by Silver_TransAm
cruise control/ traction control is on the passenger side.
dont think so, the control box is on the frame rail on the drivers side.
I know alot of guys delete the cruise but i dont know what they have to do. I just moved box out of the way
Old 01-20-2009, 06:37 PM
98Camarod's Avatar
Thats for a 98 its on the driver side. I'm not sure if its just CC or not, either way I took it off.
Old 01-20-2009, 09:08 PM
9t8z28's Avatar
thanks in advance,
eddie
Deleting it will cause no issues as it only controls the cruise. I am actually about to reinstall mine since I miss it, well, sometimes.
Old 11-21-2009, 07:32 AM
Vetal's Avatar
I have 98' TA and I have some box on the driver side rail, under fuse boxes - is this cruise control?
I laso have some box on the passenger side rail, which is round on the lower side - what is this?
Old 11-21-2009, 12:24 PM
TheFallen's Avatar
i tweaked the bracket on the cruise to tuck under the frame rail alittle more. it still in the stock location. I fit a 4" charge pipe with the cruise control module in place
Old 11-21-2009, 05:41 PM
Vetal's Avatar
Got any pics?
Old 11-21-2009, 06:49 PM
BadgeZ28's Avatar
yeah, I built a simple bracket and rotated the unit almost 90 degrees. There is a clip holding the control cable to the frame about 10 inches from the box. You need to unclip it to give you some more slack if you want to move it . I don't have any photos
Old 11-21-2009, 10:25 PM
TheFallen's Avatar
Originally Posted by Vetal
Got any pics?
all i had done was take the bracket and set it on the work bench and tapped the bent part of the bracket straight. I then had rebolted it in place and now it tucks the Cruise module under the frame rail. doing this allows more room to run your pipes since the module is now placed under the rail and out of the way
Old 11-22-2009, 05:57 AM
Vetal's Avatar
Thanx, will do smth. like that when IC will be in place
P.S. What is the 7" long box under right rail, with rounded bottom end? Has some cable going into it
Old 11-22-2009, 10:46 AM
TheFallen's Avatar
if referring to passengerside its the vaccum hold canister that is for heater controls. some have said its needed but im not sure if im going to relocate it for mine or just elinimate it
Quick Reply: cruise control question
