Cam and LT recomendations
I'm looking at adding long tubes and a different cam, I'm just bored and want to make it sound a little nicer. What do people recommend?
I'm trying to keep away from a stall for now. Its coming soon tho.
And I will be running open headers with turn downs.
I think after this Im going to make it bottle fed.
Heres my current mods.
393hp/458tq
Basic Mod List
Its a 383 Stroker,
Forged Bottom End,
Shaved Heads,
LT4 Hot Cam,
1.6 Roller Tip Rockers,
High Volume Oil Pump
MSD Ignition,
26lb injectors,
LT4 Knock sensor,
K&N Intake
160 Degrees Thermostat,
Edelbrock shorty headers,
Flowmaster exhaust,
Tuned by MC Racing,
Rebuilt Tranny with B&M shift kit.
Spohn Tubular Sub-Frame Connectors
Spohn Tubular Shock Tower Brace
Spohn Tubular Panhand Bar
Spohn 25mm Sway Bars
Spohn Rear LCA Relocation Brackets
BMR Adjustable Torque Arm
Bump-Steer Kit
Eibach "Sportline" Lowering Springs
KYB AGX Shocks and Struts
And a few other little things.
Thanks.
393hp/458tq
Basic Mod List
Its a 383 Stroker,
Forged Bottom End,
Shaved Heads,
LT4 Hot Cam,
MSD Ignition,
26lb injectors,
LT4 Knock sensor,
K&N Intake
Flowmaster exhaust,
Tuned by MC Racing,
Bump-Steer Kit
Thanks.
Restricted User
393hp/458tq
Basic Mod List
Its a 383 Stroker,
Forged Bottom End,
Shaved Heads,
LT4 Hot Cam,
MSD Ignition,
26lb injectors,
LT4 Knock sensor,
K&N Intake
Flowmaster exhaust,
Tuned by MC Racing,
Bump-Steer Kit
Thanks.
393hp/458tq
Basic Mod List
Its a 383 Stroker,
Forged Bottom End,
Shaved Heads,
LT4 Hot Cam,
MSD Ignition,
26lb injectors,
LT4 Knock sensor,
K&N Intake
Flowmaster exhaust,
Tuned by MC Racing,
Bump-Steer Kit
Thanks.
Thats gonna be loud as hell!!! better have a LOUD radio if its a DD!
ah ok I was gonna say damn lol
pacesetters are cheap and fit great, unless you want stainless steel then go LPP
what do you have done to your heads besides milling? gm847 would be a decent cam for your setup, unless your heads are unported then being a 383 with a big cam might do some harm performance wise
I'm thinking I want Stainless really.
The heads are just milled. About how much is it going to hurt me.
I'm trying not to half to tear half the engine down, I just got the interior put back together. (Someone smashed out the T-Tops)
And what could I do to regain the lost power. I cant really spend a ton on it.
I love "Bumpty-bumpty", call it a weak spot.
PS- Where can I find the GM 847 for sale?
https://ls1tech.com/forums/automatic...questions.html
I'd cam and stall personally, upgrade to LT's at a later date. the next batch of LPP's wont be out till march I think anyways. personally with your set up I'd call up lloyd elliot or AI and see what they suggest for you.
Screw the cam for now. Put a Yank SS3600 Yank in it, and a good trans cooler. Add some 3.73 gears plus some sticky tires. Ditch the shorties and get some LTs. Then throw on a Nitro Daves plate kit with a 150rwhp shot. These mods will hold you over for a while. Then when you get bored, change the cam and go with some full roller non SA rockers.
