MAF connector
Old 01-21-2009, 08:21 AM
WS6FirebirdTA00's Avatar
Default MAF connector
Guys, I am looking for what connector to purchase from Casper's for the 5 wire MAF. For the time being, I will have a connector to plug the factory connector to (the 3 and 2 wire plugs) but I would like to remove that and just have one connector.
I found this:
http://www.casperselectronics.com/st...roducts_id=937
but I am not sure if this is right for the 5 wire MAF. I am having trouble with getting in contact with Casper's about this.
Also looking for the tool to properly fix those small pieces on the wire.
Old 01-21-2009, 11:55 AM
Found it:
Connector: 413015 (1)
Terminals: 504008 (5)
Tool: 103001 (1)
Old 01-21-2009, 01:12 PM
Fast Toys Performance Parts's Avatar
Are you trying to install an 85MM and use the built in IAT sensor but not have to splice the factory harness?
If so, you want this part:
http://fasttoys.net/shop/product_inf...oducts_id=1620
Thanks!
Old 01-21-2009, 01:16 PM
No, I want to cut the wires and put the correct plug on there. All those plugs look messy.
