oil pump drive gear w/solid roller
Old 01-21-2009, 09:57 AM
slow95's Avatar
Default oil pump drive gear w/solid roller
Does any one know if you have to change the oil pump drive gear to bronze when running a solid roller? Any help would be great!
Old 01-21-2009, 11:18 AM
1redta's Avatar
Default re
your best bet is to get a solid roller with a cast drive gear. If not, you can use the polymer gear from Comp. At the very least get a new oil pump drive gear when u put a solid roller in or for that matter any new cam in.
Old 01-21-2009, 12:07 PM
Stroked96Bowtie's Avatar
The cam card will distiguish which gear type you need (cast or bronze), it could go either way. If its solid roller, then you've spent a coin not only on the cam but valve train and heads to feed that cam. So its worth the insurance to just buy a new one with the swap.
Dont forget to put assembly lube on the gear before dropping it in!!
Old 01-21-2009, 02:27 PM
slow95's Avatar
Thanks guys for the advice! I know the drive gear assembly is a piece of crap anyway because its plastic but I wish someone made a decent one!
Old 01-21-2009, 02:54 PM
1redta's Avatar
Default re
i think Moore engineering? use to make one that was Al and covered the top of the drive where it bolts to the block, I have one on my car.
Quick Reply: oil pump drive gear w/solid roller
