ls1 with sts turbo
ls1 with sts turbo
we've got a 68chevelle that i,m putting an ls1 in and an sts turbo!!!!! my ???? is whats the best head for this type set-up????... gonna put some good rods and pistons.... trying to get 900 to 1000 rwh and still have a car that i can drive on vacation with 20+mpg if i want to.....will the 317 truck heads handle this, or even the stock 5.7 ls1 heads????.....thanks monte!!!!!
As a guy with an STS, all i have to say is why?
And 1000 hp is alot of turbo back there.
With a Chevelle and a LS motor you'll have more room than you know what to do with in the engine bay.
Front mount a 88-ish size turbo and it will be great. (maybe bigger?)
rear mount!!!!
only speaking from what i've read but i would rather remote mount it to keep down engine bay temps!!!! the other advantage's i've seen are the positive charge on the intake pipe from being so long cuts down on lag!!!!and being that long actully works as a type of intercooler....but most of all i just think it's cool puttin it out site!!!! but this is all new to me....never owned an ls1 or a turbo so any and all reply and advise is greatly appreciated!!!! thanks monte!!!!
As another STS guy, with what your building I would definately think about a frount mount set up. Nothing bad to say about STS but with the right heads, cam, and a larger turbo like MonochromeSS stated, you'll reach your goal.
Although I'm curious to see if you'll get the 20+mpg vacay driver out of it. Not saying that you can't!!!
1000rwh
not trying to make 1000pony's everytime i start it up!!!! i'd like to turn the boost back and have a cool daily driver with good gas mileage.... but on the weekend go smack around some of these little boys in daddy's mustang!!!!!just don't know what head would safely hold 17to20 pounds of boost!!!! will any stock ls head get me there or will i need to go after market???? thanks monte!!!
As a STS employee I can tell you that your goals are very realistic with the remote mount setup. Are you planning on a single or twin setup? Either way we have a universal setup that will suit your needs.
As far as the heads go I would think that a ported set of 317's should do the trick.
PM me for more info on our universal system.
I also own an sts kit, and with the room you have go front mount and never look back. Engine bay heat is not going to be a problem with that much room and using proper heat shields or exhaust wrap.
I would not go more than 18psi on a stock 4bolt head for reliability sake.
As stated above you will need at least an 88mm to make that power.
How many cubes of engine you going to run?
another sts guy here and id say just do a front mount turbo, i like my sts but if i was shootin for 1000hps im not so sure that would be the way to go. id go up front and witha big turbo..and with the sts you would still need an intercooler even tho the pipes are long..and you would have to deal with turbo lag..i say front mount it
just ah toy!!!!
i know you guys are thinkin all out bang for the buck!!!! and believe me when i say been there.... had tube chassis racecars, project cars, hotrods, crazy nitros motors, heck you name it i've torn hell out of it all!!!! i guess i was kinda hope'en this time i could build something fast and reliable... heard lottsa good things bout how tough these LS motors are and still keep all the everyday characteristics[gas mileage ect]....like i said this is just ah toy and maybe 1000rwh and 20mpg is askin to much, but thats why i'm on here askin u guys???? not lookin to turn this car in to no trailor qween or track car!!!!! got one of those!!!!!just want to be able to take the family down to sonic for coke and spank **** outta the local viper ***** on the way back... LOL!!!!!just though the rear mount would be cool for toolin round the parkin lots.... but if there's something better i'm all for that to... let me know what ya'll think and thanks agin monte!!!!!
I've got an STS too. Your goals are complete achievable with the STS kit, you're just going to need a big turbo out back!!! 1000RWHP is cool to say you have but good luck hooking on the street. It's just me but I'd rather be hooking with 500-600rwhp than spinning with 1000. Horse power you can use is what's needed for the street.
Of course there is a thing called a boost controller that works great when you just need that little extra kick!!!
streetable power!!!!
hey shawn, thanks for the feed back man.... your right about having it and being able to use it on the street being two different things!!!! so we are going to get use "morrison chassis" and see what we can get to the ground!!!!
ok let me ask this a different way!!!! say i was mounting the turbo up front and wanted to get in this power range what head would u fellas use? thanks monte!!!!
