Grinding/Rubbing noise??
Old 01-21-2009, 10:52 PM
JB_97ws6TA's Avatar
Default Grinding/Rubbing noise??
Installed SFC as well as K-member out so the factory torque arm has been removed and reinstalled. Under hard accelerating either from a dig or roll I get a strange grinding/rubbing noise from the rear somewhere, one thing I do know is that it is not tires rubbing fenderwells...any ideas let me have em the only real idea I have is that I didn't have weight on wheels when I tightened the torque arm, would that cause this noise?? Also are you supposed to go back and retorque SFC after some mileage??
Old 01-22-2009, 07:54 AM
Stroked96Bowtie's Avatar
Have you been under the car to inspect things? If its under acceleration it sounds like it could be something rubbing with wieght transfer.
Old 01-22-2009, 09:19 AM
JB_97ws6TA's Avatar
Yeah I understand that it has something to do with wieght transfer but it is almost impossible to duplicate with the car in the air. I was hoping that someone has had something similar happen to them so I could gain a little bit of direction instead of going in blind
Old 01-22-2009, 09:26 AM
MadMike 97 Z28's Avatar
not sure exactly how it sounds but is it possible that the 10 bolt is making the noise you're hearing.
Old 01-22-2009, 09:38 AM
It could be so many things. The only time I had a similar issue was when I put in a LS1 DS, under acceleration it would rub my saftey loop. Once I got under the car it was pretty obvious, look for shiney spots on things. I also had my torque arm hitting the under side of the car at once, but Ive got an aftermarket piece.
Old 01-22-2009, 09:42 AM
Elliott's94Z's Avatar
I experienced the same thing after I put on my SFC..jacked it up and re-torqued the bolts to a tad over a 100ftlbs and haven't had any issues since..just an idea of what it may be.
Old 01-22-2009, 10:38 AM
JB_97ws6TA's Avatar
which bolts did you tighten to 100 ft lbs?? The LCAs and the 4 in the front that attach to the frame rail?? That is what I was thinking I was just going to put it up on a chassis lift, loosen everything with weight on wheels and then torque the snot out of it.
Old 01-22-2009, 11:45 AM
The actual bolts for the SFC @ a 100ftlbs. That's what Ryan over at UMI suggested. I bought the bolt in style. I would just go through everything underneith and re-tighten. I did since it was on the rack.
Old 01-22-2009, 12:22 PM
UMI Sales's Avatar
Thumbs up grinding noise
Hello,
All it takes is even though you think everything's tighten enough on the SFC, they have to be tighten evenly....just food for thought
Thanks Again,
Brad
Quick Reply: Grinding/Rubbing noise??
