Oil pressure for my mechanical oil pressure gauge
Old 01-22-2009, 01:15 PM
Blakout GsT's Avatar
Default Oil pressure for my mechanical oil pressure gauge
Hey guys,
Can someone tell me where are all the locations on the LS1 block where i can get oil pressure for my mechanical oil pressure gauge. Im tired of switching out the electrical sensor. Its being the 3rd time my sensor went bad, pegged my oil gauge. Its 2001 c5 corvette thanks guys.
Old 01-22-2009, 01:52 PM
TORCHD 02 TA's Avatar
Originally Posted by Blakout GsT
Hey guys,
The mechanical one has oil that runs in the car right? If that is the one i am thinking of, i would not want oil running in my incase something happens
Old 01-22-2009, 02:00 PM
NC98Z's Avatar
Talking
Here one. Right above the oil filter.
Attachment 162439
Old 01-22-2009, 04:07 PM
Its not going in the Cabin. I'm keeping in the engine bay. i don't want an oil leak in my interior! NOWAY!
NC98Z Thanks pal
Old 01-22-2009, 04:43 PM
NC98Z Thanks pal
Whats the point of haveing a gauge if you can not monitor it then?
Old 01-22-2009, 08:41 PM
9000th01ss's Avatar
Attachment 162439
Thats where I put mine. I thought I read that the vettes had the stock sender there.
Anyway, on an f body that piece has the right size hole in it already to run a 1/8" NPT tap through it and drill the last 1/4 inch or so with a 3/16" drill bit.
Old 01-23-2009, 01:06 AM
anywhere else?
Old 01-23-2009, 02:30 AM
deadhorse66's Avatar
I made a little adapter fitting out of an old oil pressure sensor. Ground the top of it off and drilled & pipe threaded it. Works nicely, if you don't care about having oil pressure displayed on your IPC.
Old 01-23-2009, 01:33 PM
Does anyone have pics of the different locations. for the one by the oil filter, do i have to drill a hole through block then tap it?
Old 01-23-2009, 03:47 PM
JoeyGC5's Avatar
Attachment 162439
Just like the picture. There is a blind hole in the extension block that can easily be drilled and pipe tapped (1/8 NPT) for an additional oil pressure sensor or feed line can be added. The Vette oil pressure sensor is in the same spot as the f-bodies and trucks.
Old 01-23-2009, 04:55 PM
9000th01ss's Avatar
I'd rather drill a hole through a 5 ounce cast aluminum adapter than go drilling into the engine block.
Why don't you want to use the piece above the filter?
Two bolts and you've got it on the bench to work on.
The hole is drilled, you just need to tap it. Then drill a small hole to open it up to the oil port.
Can you communticate better? People are going to recommend the easiest location until you give good reason why you don't want it there.
I found a pic of mine.
